Ignition module
Old 01-02-2007, 06:41 AM
Arnie
Arnie's Avatar
Default Ignition module
I disconnected mine and connected to a mkII golf 16V module, the car still start, I haven't tried driving it, but I noticed that VAG's ignition module fits the escos, are they interchangable? I'm planning to have a coil pack conversion and it needs two module, if they are all the same then I can save a bit and just use my mate's apare
Old 01-02-2007, 10:51 AM
ossie cossie
ossie cossie's Avatar
i am keeping an eye on this post they will be easier to get here in OZ as well (if they fit)
Old 01-02-2007, 12:21 PM
NO NO NO,
BUT same as,
ALFA ROMEO 164 2.0i Turbo 88-92.
FERRARI 328 GTO 89 onwards
FIAT
ARGENTA 120 2000IE 83-85
CROMA 2.0IE 85-89
CROMA 2.0IE 90-93
CROMA 2.0 IE EUROPA 90 -93
CROMA 2.0IE TURBO 90-93
CROMA 2.0IE TURBO EUROPA 90-93
CROMA 2.0IE TURBO 85-89
REGATA 100S IE 1585cc 86-90
TIPO 1.8i 16V SPORT 89-93
TIPO 1.8 Spi 90-93
UNO TURBO IE 1299cc Cat 85-89
UNO TURBO IE 1372cc Cat 89-94
FORD,
ESCORT COSWORTH 2.0I TURBO 1993
SAPPHIRE/SIERRA RS COSWORTH 2.0 86-90
SAPPHIRE/SIERRA 4X4 COSWORTH 2.0 90-93
LANCIA,
DELTA 1600 IE 86-88
DELTA 1600 IE 89 on wards
PRISMA 1600 IE 86-89
THEMA 2000IE TURBO 85-88
THEMA 2000IE TURBO 89 onwards.
Phew finished !!,
By the way WIM050 is the webcon number.
Old 01-02-2007, 01:11 PM
Arnie
Arnie's Avatar
what will happen if the wrong one is used? (not that I'll try knowing it won't work)
Old 03-02-2007, 08:18 AM
It may go bang, your ECM may go bang or it may work!!
Most ECM's work on similar voltage/resistance as do any sub ignition circuits.
ps have you got the number of the local fire brigade!!
mark94
10-10-2023 06:52 PM
tankybaby66
06-02-2016 02:24 PM
beller
21-09-2015 04:13 AM
Dr. Ickxs
15-09-2015 10:15 PM
marky_g
12-09-2015 04:26 PM
Quick Reply: Ignition module
