Escort Van - 1.8D to 1.8TD engine swap?
Old 12-11-2006, 12:15 AM
Mk5_XR3i_130
Mk5_XR3i_130's Avatar
Default Escort Van - 1.8D to 1.8TD engine swap?
Hi guys,
can anyone tell me whats invloved in swapping the 1.8d engine in my 98 escort van for the 1.8td lump?
what parts would be needed?
or is the turbo a bolt on option with the manifolds?
Thanks Matt
Old 12-11-2006, 07:27 AM
GazzaG
GazzaG's Avatar
I think its a straight swap, don't take my word for it tho.
Old 12-11-2006, 01:16 PM
Mk5_XR3i_130
cool i was hoping it might be
need more power but need to stay with diesel so the td lump is my best option i think
Old 12-11-2006, 01:39 PM
dave green
dave green's Avatar
I no the heads are the same
Dave
Old 12-11-2006, 04:17 PM
Mk5_XR3i_130
cool my main concern is the wiring and ecu?
so in theory i could bolt on the manifolds and turbo fit new ecu
and gain 20bhp?
Old 12-11-2006, 04:28 PM
dave green
dave green's Avatar
sounds like it will be a simple transplant.
Dave
Old 13-11-2006, 01:14 AM
Paul_RS
Paul_RS's Avatar
I know someone who has done this, i'll find out what they did for you tomorrow hopefully
Old 13-11-2006, 07:29 AM
Mk5_XR3i_130
sweet, cheers dude
Old 01-02-2007, 12:28 AM
rosie
rosie's Avatar
bolt all bits on ur engine & pipe it all up, theres allot of bits 2 bolt on thou.
all piped up wouldnt need ecu
allot of messing about thou
Old 02-02-2007, 01:55 AM
bortaf
bortaf's Avatar
dont the turbos run a lower comp though compaired to the non turbo?
Old 02-02-2007, 11:53 AM
fraser9764
fraser9764's Avatar
according to derv doctor the internals of the engine are different, i was thinking about doing this to my van but they dont recomend it. its a straight forward swap though, find a TD out of a mk1 mondeo or any of the earlier escorts and there is no ecu to wire in. make sure its the 90 bhp engine though, (the one with the intercooler). its easy to make some reasonable power out of them too as you can adjust the fueling on and off boost and the boost itself. with a front mounted intercooler and a bit of fettling by someone who knows what theyer doing i have seen them making 150 bhp
i would highly recommend derv doctor, they fiddled about with the fuel pump on my n/a 1.8d a few weeks back and its a million times better. cant think of the website off hand but google it if u want.
Old 03-02-2007, 02:15 AM
Mk5_XR3i_130
in the end i bought a complete car, an escort lx tdi to use the engine and box
Old 03-02-2007, 08:09 AM
GazzaG
GazzaG's Avatar
Mk5_XR3i_130
you raped that car.
Old 04-02-2007, 11:38 PM
Mk5_XR3i_130
Old 10-02-2007, 10:36 PM
brizie
brizie's Avatar
Default nice
keep us updated mate,going to do this conversion myself soon so expect lots of questions
Old 18-08-2007, 11:36 PM
vinnyvangough
vinnyvangough's Avatar
Default Transplant.
Just done this conversion myself. I put a 1995 td engine into my 1999 van. Didnt go so smooth. for some reason, it wouldn't start on the key. You have to splice into the loom. What i done was fitted a start switch to bypass this problem. Another thing is i have found the intercooler is v close to the underside of the bonnet. i got a vent to go in soon but in the mean time i have lifted the back of the bonnet 30mm to help with cooling. hope thats some help.
Old 19-08-2007, 11:27 AM
ScORTED
Project Money Pit
ScORTED's Avatar
just so you know you can transfer the pump and turbo onto any other 1.8 endura diesel, they all run the same internals
Old 19-08-2007, 11:31 AM
vinnyvangough
Default Turbo diesel pump
Very true. At the moment i'm having to run my td on a straight derv pump cause the turbo pump seals gone and leaking derv like u would never believe (60 mile to Ł20) anyone know where the best place is and price to send it away to get reconditioned??????? its only done 44000!!!!!!!
Old 19-08-2007, 11:43 AM
ScORTED
Project Money Pit
ScORTED's Avatar
just get another one from a brakers mate...
Old 19-08-2007, 11:55 AM
vinnyvangough
Default turbo pump
Yea, might have to. Last one i found the bloke wanted Ł300 for. Thats what i paid for the bloody engine!!!! lol
Old 08-04-2009, 05:56 PM
benji1987
benji1987's Avatar
Question am i being thick lol
hi there, i am about to do a engine change from n/a derv to td, i have an endura engine am i being thick but what your saying is i can just bolt on a turbo and other bits to my existing engine and all will be ok? or was you talking about an actual td engine?cheers
Old 08-04-2009, 06:18 PM
ScORTED
Project Money Pit
ScORTED's Avatar
it is reputed and I belivev the internal are the same
Old 09-04-2009, 08:16 AM
benji1987
benji1987's Avatar
Smile
hello there thanks for the info great help, one last thing where can i find out the compression ratios on the turbo and non turbo endura? many thanks benji
Old 16-06-2009, 06:34 PM
christo
christo's Avatar
hi all! im from south africa and got a bantam 1.8 diesel with the front end lookn like ur mk5 zetec s! i got a import engin from the uk the mk6 escourt 1.8td! now my rev counters not working aswell as my brakes and my glow plugs get no power from the ignition! the coding of the key r bypassed already! can u help please?
Old 17-06-2009, 05:03 AM
christo
christo's Avatar
pls help
Old 19-07-2009, 04:09 AM
Ford Van Man
Ford Van Man's Avatar
Yes you can just swap the lump but you might have to do some wiring adjustments to get it to start but it a straight forword conversion thou
Old 19-07-2009, 04:15 AM
Ford Van Man
Smile
Chriso
By the battery there should be a black box in there should be fuses make sure done of them have blown and check all your earth wires too as that might cause the revcounter to play up
Old 19-07-2009, 04:21 AM
Ford Van Man
Smile
you cannt put a turbo on a non turbo engine the pistons will not work with a non turbo engine there not much difference in out put side of things i found the non turbo engine got more pulling power then a turbo engine
Old 23-07-2009, 05:54 PM
lozi
My Cossie Ate My Money
lozi's Avatar
does anybody know the power outputs of the 1.8D and 1.8TD escort vans?
im looking into buying one but my mate rekons the non turbos are the slowest thing on the road and are not even that good on fuel?
Old 27-07-2009, 11:44 PM
Ford Van Man
Smile
Hi Benji
Il try and finf out about the compression ratios on the turbo and non turbo endura?
the Endura-DE engine was a normally aspirated engine producing 60 PS (59 hp/44 kW). However for other Ford Escort (Europe) and Ford Mondeo the Endura-DE also featured a turbocharger producing 75 PS (74 hp/55 kW) and some models also had an intercooler and these produced 90 PS (89 hp/66 kW) This is all i can find on this hopes this helps You Benji
Old 27-07-2009, 11:50 PM
Ford Van Man
Smile
Hi i got a non tubro 1.8 d Van best thing i done i buying it it goes well keeps up with my mate in a 2.5 turbo d ice cream van i can do 90 mph in it on a motorway i had a 2000 on a v reg ford focus before 1.8 turbo it was as flat as shit my van a loads better fuel graet on it too 500 miles too a tank full too
Old 08-09-2009, 07:44 PM
Roscopeco
P8 Managed S1 with ALS
Roscopeco's Avatar
I am too wanting to do this mod on my van but someone has mentioned that you have to modify some of the wiring ! Could anyone out there tell exactly what wants doing to the wiring before i do the swap ? Any help will be greatly appreciated !
Old 09-09-2009, 10:14 AM
Lee Ivatt
Shizzle My Nizzle
Lee Ivatt's Avatar
Had a 1.8 D N/A was fine.
Kept up with traffic easily and I was actually supprised how nippy it was for a non turbo.
Fuel was also good, I dont ever remember thinking this thing is bloody thirsty.
Fully loaded the power was down and the front sterring was quite light, but other than that I couldnt fault it.
A good cheap van, and something of a classic i really feel now days, as I feel this was really the last car derived van made.
everything now is transit connect style.
Old 11-09-2009, 06:01 PM
christo
christo's Avatar
hi! my key coding were bypassed! the black box on the diesel pump were removed and connected directly 2 the ignition! its works well like that
Old 21-09-2009, 07:55 AM
jamez265
jamez265's Avatar
I know someone who has done this, i'll find out what they did for you tomorrow hopefully.
Old 21-09-2009, 05:16 PM
Roscopeco
Roscopeco's Avatar
Thanks fellas most appreciated ! The van is my workhorse so need to know that when i tackle the task it gets done in one hit so i can use for work on the monday morning as my other cars are my toys !
Old 17-10-2009, 01:00 AM
twolitrepinto
twolitrepinto's Avatar
I did this conversion on my van, and now i ended up changing the whole engine, box and subframe anyway, it worked, but not for long...
heres the list of what i did:
Swapped exhaust and inlet manifolds over to the TDI ones, changed the oil filter housing to the TD one as it had an oil feed for the turbo built in,
theres a small pipe going into the bottom of the block on the TD for the turbo oil return, on the NA block you need to tap out the core plug here and put the pipe in here from the other block.
reroute the water pipes through the oil cooler on the TD filter housing.
change to the TDi injection Pump.
if your TD pump is the later type with 3 black wires going to the fuel shut off solonoid, remove the shroud that is supposed to prevent access to it, remove the solonoid and replace with the older type (just one ignition live)
then put another wire from the starter solonoid wire (ignition barrel side), to the starter solonoid wire (black or black and red wire). it has a single pin plug that runs near the brake fluid pot..
this eliminates all the hastle of the chipped key problems that i ran into...
also you will need to either get a custom exhaust made or get a TD escort van exhaust which are not cheap new, the original van one will not fit the TD manifold and if it did, it will restrict and cook the engine anyway
bear in mind that the TDI engines are intended to sit slightly further forward due to the intercooler fouling the bulkhead, you can just remove the plastic part of the bulkhead which i did but you will have a problem getting anything onto the air intake because it is so close to the brake servo. it is possible and it does work but it doesnt look right.
it took me 2 evenings to do all the above without rushing too much.
it made a huge difference in performance, the following day i towed a cavalier full of spares on a trailer, with a van full of tools 10 miles to arena essex and back with no problems. unfortunately a few weeks later the head gasket and the fuel pump failed almost simultaniously so i decided on changing the lot...
if you plan on using the TD box you also need to change the subframe, linkage and gearstick because the TD box has an extra mount on the subframe, diffrent linkage, lift up reverse and a longer clutch cable.
the speedo drives will just swap straight over but you will need to swap the plugs over from the reverse light switch.
if you want to change the lot, i would recommend sourcing a whole escort TDI and just drop the lot out of the bottom with the gearstick still attached etc. this is what i did the 2nd time, hell of a lot easier in the long run. and while its out you may want to do any tweaks to the pump now if you are going to up the fuelling, because its quite difficult to get your hand down the front when its in.
the van will now easily spin up through 1st and 2nd in the dry, and its better on juice than before (unless i floor it everywhere).
all in all, i would say it was definately worth it, because if you are anything like me, the 1.8 diesel used to make me angry everytime i hit a hill! i no longer have this problem.
sorry for such a long post, but maybe this will shed some light on the subject.
Old 17-10-2009, 08:02 AM
jonny s2
jonny s2's Avatar
i have a mk4 1.8d van,and plan to fit a mk1 mondeo engine this should fit no bother? but is there any wiring need doing i run this daily so couldnt be off the road any longer than 3 days
Old 18-10-2009, 04:06 PM
twolitrepinto
you may have to remove the power steering etc from the mondeo lump, or swap it over, but if ur van has power steering and the pumps on the bottom not the top, the mondeo sump doesnt have the bolt holes to accomodate for the pump at the bottom,
you will probably have to swap all the mounts,
i dont know what you would do about the gearbox, iirc the mk4 has a crossmember going from front to back with 2 mounts, mk5/6 escort & mondeo is completely different gearbox mount wise.
if the engine is a TDi with the ECU like mine was, you might have a hard time with the wiring as i did, i have got the whole engine bay loom and ECU connected up with the MAF etc, but i dont think its actually doing anything, it will run anyway if u bypass the immobilised pump.
my van never had an ECU, and the connector up by the bulkhead was the same but i dont think the wiring going on the other side of the plug is the same. my glow plug relay has no live going to it, and when i put a live to it, something in the diesel pump starts buzzing, it runs like crap, and does all sorts of wierd things. im just going to put the wiring back to standard and get rid of the ECU,
more hastle than it was worth imo.
Old 01-12-2009, 03:19 PM
jghs83
can you smell purple?
jghs83's Avatar
Location: normally dewsbury west yorkshire, but i could wake up anywhere!
mondy mk2 td inlet and 'cooler wont fit. i found out the hard way
id already spent about 6 hours on the buffer!
Quick Reply: Escort Van - 1.8D to 1.8TD engine swap?
