transit connect speedo fuse???
Old 17-07-2006, 08:38 PM
cossydave377
cossydave377's Avatar
Default transit connect speedo fuse???
any ideas on how to remove the speedo fuse on a 2005 transit connect.
i want to cover loads of miles and dont want to clock the miles up
not realy ive lent my van to somebody and i think they have done just this.
is it possible?
Old 20-07-2006, 06:08 AM
They may have just disconnected speedo drive ?, not too sure about these trannies.
Old 20-07-2006, 06:57 AM
cossydave377
not sure what they have done but i think the van may have done about 3000-3500 miles
they were only going to use it for 500 miles MAX!i thought if you disconect the speedo when you put it back in the ecu clocks the miles back up?
duno idiots at the pub talking crap i guess?
Old 21-07-2006, 03:50 PM
For the ecu to know it has even moved it needs to receive a speed reading, it is possible that it uses another sensor if it has one but I see no need for it have another, for what function, therefore if it does no know it has moved it cannot clock up miles it knows nothing about.
If you want me to look in to this in more detail I will try to get a wiring diagram for the van and let youm know if there is any way they could have done this.
Old 21-07-2006, 04:27 PM
cossydave377
if the speedo was taken out wil the van ecu still run and fuel correctly?
if you have time i would like to know how this could have been done, but if your tied up with other things then maybe when you get 5 mins?
mark94
10-10-2023 06:52 PM
Mark RS
12-10-2015 06:01 AM
Neil Clark
21
01-10-2015 07:02 PM
stevecfrst1
30-09-2015 05:18 AM
IainRS1700T
25-09-2015 06:44 AM
Quick Reply: transit connect speedo fuse???
