rebuilding a zetec engine
Old 20-04-2006, 07:11 PM
Moondust_crust
Moondust_crust's Avatar
Default rebuilding a zetec engine
looking to rebuild a zetec 1600 engine, dont want to alter much want it pretty much standard spec, what things do i look out for when taking it apart? wear on stuff? only done 60k.
cheers in advance peeps!
Old 20-04-2006, 10:23 PM
KillBill
KillBill's Avatar
I need to rebuild my 1.8 silvertop, as the piston rings are going... so would be interested in hearing any general advice and pitfalls also....
Old 21-04-2006, 06:22 AM
Moondust_crust
come on people there must be some websites or links you can give us?
Old 21-04-2006, 11:28 AM
dipy
dipy's Avatar
check play in valve guides and replace on a need to do basis, bores need honing with a fine grit as a min, look for sratches on the bores and check condition of oil scrapper rings as these tend to snap - which leads to further investigation. check big end and main bearings for wear marks which may signal pump problems. recut valve seats. always replace cam seals as these tend not to seal again. get the crank journals checked and polished or rolled as needed. get oil ways flushed. look at hydraulic lifters for scoring on side as these cause oil leak down pressure losses.
as a min you need:
new big end bearings (Ł20)
new main cap bearings (Ł30
new pistons rings (Ł80)
hone bores (Ł25)
oil pump clearances checked, new relief valve and spring
crank journals checked, work as necessary (Ł35 polish)
bottom end gasket set (Ł25)
valve faces/seats recut (Ł2 per valve)
new valve stem oil seals
new cam seals
head gasket set (Ł40)
all new bolts and fixings
Usually best to get the head decoked and block chemical boiled (both for Ł40)
prices are just guidelines for some of the stuff i've bought previous, i imagine they are still round about todays prices......
Old 21-04-2006, 12:07 PM
Moondust_crust
do haynes do a zetec rebuild manual does anyone know?
Old 21-04-2006, 01:29 PM
dipy
dipy's Avatar
don't know, but alot of the removal/refitting is covered in the fez manuals 92-95 from the xr2i 16v & si
Old 21-04-2006, 02:07 PM
Red16
Red16's Avatar
check out my thread for pics and step by step how to strip a
zetec bottom end https://passionford.com/forum/viewto...=asc&start=760
cylinder head https://passionford.com/forum/viewto...=asc&start=800
no help to you for building the engine but at least you can see whats what inside
Old 21-04-2006, 05:43 PM
sexr3i
isn't it
sexr3i's Avatar
just swap it for a 1.8 or 2 litre cheaper than buying bearings, pumps and rings
Old 21-04-2006, 07:23 PM
Moondust_crust
cheers red, thats a help mate, might need some more help so i might bombard ya with some questions lol. got the engine today so started to strip it....
Old 21-04-2006, 09:09 PM
Moondust_crust
dipy mate, problem is i cant tell whats got wear on it or not, first time ive taken one apart to rebuild before, red's thread was very helpfull doesnt look too hard, its just knowing what stuff to replace......
Old 22-04-2006, 01:36 AM
KillBill
KillBill's Avatar
That other thread is class, shows in detail what exactly the inside looks like, which makes Haynes seem a bit more clear now
I've also never stripped an engine before, so this is very helpful.
Cheers lads
Old 22-04-2006, 10:35 AM
Moondust_crust
got a couple of pics , and already i need help .
seen some people blank off this hole, there was a big black metal box plugged into it do i need it? or can i blank it off?
also what about all these pulleys? only need the bottom one connected to an altenator dont i?
cheers for all the help!Ź
Old 22-04-2006, 05:43 PM
sexr3i
isn't it
sexr3i's Avatar
out of interest why are you re-building it if it's only done 60k? I've seen zetecs hammered every day and are still going strong at over 100k. Things to look out for may be different depending on the circumstances before the rebuild. I'd just whip the sump off, check the bearings and replace if necessary, rocker cover off and check cams and tappets and note the condition of the oil. Should all give you a good clue to the health of the lump. But like I say, if the engine has had problems, then I wouldn't bother rebuilding it as a 1.8 from an xr3i or Si etc is cheaper to buy than all the rebuild parts and will drop straight in with an ecu swap.
the big hole on the block is an oil breather, the pulleys, 1 is a waterpump (you need that), one is a tensioner (you need that), one is PAS pump, you could do without that but it'll be harder to turn the wheel, or if you're putting the lump in a non PAS car then get rid of the pump and you need a shorter belt. you've got the alternator yeah, and the other is an idle pulley to get the belt going where it needs to go whilst getting plenty of surface area on the other pulleys.
Old 22-04-2006, 05:56 PM
Moondust_crust
to be honest im not wanting to do a complete rebuild i juat want to make sure its all ok before i slot it in place, its had no problems in the past its a good runner, when i drained the oil it came out clean to looks like its been looked after (or just had a change) can i block the hole is the block off and just use the breather off the rocker cover?
so basically with the pulleys i can just junk the pas pump at the top and run the bottom the way they are (with a shorter belt), is it true the belt can catch on the inside wing?
engine mounts im ok with and inlet side of things cus im using the inlet off a xr3i cvh with one of jano's plates, exhaust im a bit worried about, someone said a st170 one will fit but im not sure about that,
and what about clutch and flywheel, i take it i need a mk4 clutch, but can use the zetec flywheel as it has the cutouts for the sensor?
cheers in advance your a star!
Old 23-04-2006, 12:51 AM
KillBill
KillBill's Avatar
My Zetec burns oil like crazy and its done 130k... I get blue smoke out the back if I floor it, so I'm pretty sure the rings need attention. This is my main reason for wanting to rebuild / replace the engine.
That said, I have heard reports that this can also be caused by problems in the bottom end... has anyone experienced issues like this, and if so, what was the cause ?
TBH I was surprised my engine has kicked the bucket at 130k, I see loads of other Zetecs at 150-200 and they still seem fine.
Old 23-04-2006, 12:49 PM
Red16
Red16's Avatar
no worries, if i can help you with anything i will
Cheers lads
its easy really, just take your time, take loads of photos if you got a camera handy, theyre handy for the where did this bit go moments nothing should have to be forced, should all go together nicely, if it doesnt somethings not right and make sure everything is torque'd up properly.
Old 23-04-2006, 03:14 PM
sexr3i
isn't it
sexr3i's Avatar
I never blocked it off, dont see the point tbh, why would u want it to not breather as well as standard? i think zvh conversions block it off, but im sure they have their own reasons for that. probly exhaust/turbo clearance issues?
yeah you just get a shorter belt, it's not a ford belt though so i ended up using a couple of different ones from motor factors before xr4x4rs off here found me the part number for one that fitted.
you're running the zetec on your old cvh management? will need setting up you know, mfi or efi?
you can get an ashley exhaust manifold that will bolt up to your system, or do what i did and just cut the flanges off and sleeve the new manifold to your system.
Zetec clutch works fine, and my one looked a fair bit beefier than my mk4 clutch. flywheel should be fine too, it's just the 130 spec flywheels that need changing for a 105/eficvh etc.
I've got a diagram of the cooling pipework mods you'll need too. Keep us posted
Old 23-04-2006, 03:18 PM
sexr3i
isn't it
sexr3i's Avatar
problem is, you never know how the previous owner treated it. I made sure that i had a full/decent service record and tons of receipts with my donor car, even tho it was just 300 quid cos the body was shot. drove it home 40 miles to make sure it was sweet.
my neighbour has a mondeo that i service for him, 170k miles and no signs of burning oil, he treats it well. we change the oil regularly, and he always lets it tickover for a minute before he drives off. Things I always do is get in the car, start the engine and then put seatbelt on and radion n that so the ol gets a few seconds to get up the head.
Old 23-04-2006, 03:52 PM
Moondust_crust
i just dont like that massive box sitting on the front of the engine and wondered what other people had done.
ive sent xr4x4rs a pm but he cant remember the belt he used, said he wil ask his mate cus he uses the same belt so will get me the part number.
yes mate old management, dont see why it should need setting up, same ecu and inlet so all the sensors just plug straight in, also its efi so that makes it all the easier.
ahh good news about the clutch and flywheel then, and the gearbox will just bolt straight up?
if i could have them diagrams mate that would be handy too, cheers mate.
Old 23-04-2006, 07:55 PM
KillBill
KillBill's Avatar
I do the same, in fact I try and never rev it above 2kish until it's warmed up too. In the mornings I normally start the car, then take off the anti theft device, throw my coat in the back, connect my MP3 player, etc. I never just drive off.
I'm well used to waiting a minute anyway, as I normally drive old Citroens, and give the suspension a good while to rise before moving.
Pity it seems too late for this car .
I've been looking into the possibility of a second hand engine today, but I really don't know where to get one thats not trashed. Was talking to the local scrapper, and he said Ł150 for one, but thats with totally unknown history and no guarentee whatsoever.... I found about 15 Mondeos in the yard, mostly diesel, but a few 1.8 and 2.0 petrols... most had mileage similar to, or higher than mine. I found one in an estate that had only done 80k, but someone had removed the leads and plugs, and left the bonnet lying open
I did find a nice 2.5 Duratec V6 too, but it was in a Mk2 that someone had removed the bonnet of, so it was lying there exposed...
Mind you, an engine would be much easier to rebuild if it wasn't in the car....
Old 23-04-2006, 08:59 PM
Moondust_crust
theres some ones on ebay mate but as you say you dont know how they have been treated, took the rocker cover off mine today and its mint under there, the alloy isnt even stained, but my mate bought a zetec the other day, had done 55k and to be honest it looked like it hadnt had an oil change in years and years. good luck.
cheers mark.
Old 24-04-2006, 04:08 PM
sexr3i
isn't it
sexr3i's Avatar
Best bet is to look in bargain section of auto trader or similar, a 1.8 escort/ 2.0 mondeo with FSH but rotten and failed mot on wishbones or something for example where it's not worth fixing. go look at it, take it for a run, ignore any suspension noises etc but just feel for any flat spots, look for any smoke etc.
Thing with using the old management on the new engine is, the 1.6 ecu will think it's running the cvh. even with the cvh inlet, sensors etc plugged in, you're now gona be running a 16 valve engine with different power delivery, fuelling/timing requirements etc so you'll not get the best out of the engine until it's been set up. worst case scenario, it'd be running wrong enough to melt something.
Yeah, assuming the zetec clutch has plenty of meat left on it you can bolt the whole assembly straight into the cvh bellhousing without touching it. if you've ever mated an engine and box before then you'll know about getting the clutch onto the input shaft so it'll need a wiggle but once popped in you're done.
Piccy of cooling system below, you need a t peice in the bottom rad hose or you'll end up with 1 too many hoses which will empty itself onto your drive within seconds some people block off one of the hoses to the thermostat, but thats not gona help cooling is it?
Old 24-04-2006, 04:49 PM
KillBill
KillBill's Avatar
That's good advice there mate, in fact I bought the autotrader this afternoon to look for a shunter
Old 24-04-2006, 04:51 PM
Moondust_crust
not good then, so from your sig i can see you have used the zetec manifold? what wiring do you have to change to run the new engine then, its an efi car so apparently it makes it easier.
thanx for all your help mate i do appreciate it
Old 27-04-2006, 07:59 PM
sexr3i
isn't it
sexr3i's Avatar
I used the entire zetec loom, inlet and ecu, my car was mfi and i switched to the efi zetec management. There was a fair amount of wiring involved, had to put together a fusebox and mini-loom to feed the ecu, lambda and get the ignition lives and change fuel pump and ignition relays. On an efi 3i, I wouldn't say it's any easier really, we just use your existing fuel pump relay. Still needs the new fusebox and loom section.
It's not the only way to go about things but IMO, value for money-wise etc then using the management that previously had the engine running is the best way. Other people do it your way and use their old management and a conversion plate for the inlet altho I don't regard it as optimal compared to the "proper" setup that the engine was running on from the factory.
You'll then have to shell out for management that you can map to suit the new engines requirements, although again, there is an upside to that as when you inevitably decide you want more power, you can add your tuning goodies and have it mapped again to suit on a reasonable budget. and when you swap to a bigger lump, get just needs a re-map and you're laughing. Initial outlay is more, but if you're keeping the car then you're sorted for future modifications rather than having to keep swapping looms and ecu's.
I've got my engine in and running on the zetec setup, had it in for almost a year I think, I'll be running throttle bodies hopefully this year so I'll get it mapped, then once it's had a shakedown period with the 1.8 still in, I'll fit a 2.0/2.1 that I've been planning for a while and re-map it. Saves risking anything not working properly on the new engine and shagging it by fitting it all at once and something breaking.
04-01-2024 02:36 PM
martsmotor
Ford Focus Range
27-08-2015 08:08 PM
coozer
Ford Focus Range
15-08-2015 10:26 PM
Zoggon
10-08-2015 10:39 AM
Quick Reply: rebuilding a zetec engine
