Fitness / Weight Training Discussions Don't drive around with 4 chins! Chat to like minded folk in here and get yourself back to a decent health and fitness level in no time.
Pain, ALL THE TIME...
Old 15-03-2006, 04:21 PM
Stu @ M Developments
PassionFords Creator
Stu @ M Developments's Avatar
Default Pain, ALL THE TIME...
Normally in shoulders and upper arms. Like a constant dull ache...
Can too little protein cause this?
Old 15-03-2006, 05:49 PM
FastFordChris
FastFordChris's Avatar
sounds like stain on the muscle/tendoms
dont forget your working them harder then they probably have ever worked before at a constant level so theres gunna be some pain as the muscle begins to grow and adapt. this is where muscle memory comes in to play which is why keeping up a ruteen is important.
do some stretches every couple of hours nothing over the top just be gentle, as this all helps with healing and growth.
is its still giving you some trouble try the old hot cold trick as that'll help to.
Old 15-03-2006, 08:34 PM
Thanks for the advice
Old 15-03-2006, 09:19 PM
Paul Eggleton
Paul Eggleton's Avatar
COuld very well be joint pain Stu. If you have been training solidly for a few months now it maybe beneficial to have a week off or just go reallly light for a week to see if it goes away.
Paul
Old 16-03-2006, 10:28 AM
dexterc
dexterc's Avatar
If it is muscular pain, there are a number of things you can do for quicker recovery.
Deep heat or similar, rubbed into the muscles can help. Especially if you wrap it afterwards. The hot-thing has already been mentioned. Recovery workouts a day or so after the workout can work. Basically a very light repetition of what youve been doing to get extra blood pumping around that area. Say youd had a heavy Bench press day, you could do 4x20 pressups or something. It shouldnt be strenous.
Sleep is also really important. I found that taking herbal sleeping tablets made me sleep loads better and recover quicker. Problem is, I dont take any caffeine, nicotine or alcohol, and it hasnt worked as well for anyone I know that does thats tried similar tablets.
Old 16-03-2006, 10:52 AM
Excellent, thanks guys...
I will take it a little easier for a while, and in 1 month im going to teh nurburgring so am forced to take 8 days recovery period, so ne need to be slacking before then
Old 16-03-2006, 02:21 PM
Ben26
Ben26's Avatar
Default Re: Pain, ALL THE TIME...
no !!
Old 16-03-2006, 04:54 PM
no !!
Are you certain? The way i understand it all working i feel it possibly can, but would rather take the correct info from someone whos 1 hundred percent certain, as opposed to my 80%
Old 16-03-2006, 07:01 PM
Ben26
Ben26's Avatar
well i am doing sport and fitness at college , all protein does is makes your mascles grow ( in simple terms)
it could be somethin like artheritis of the shoulder joint ???
were does it actually hurt ?
what type of pain is it ??
is it a constant pain ??
Have u suffered fromt his b 4 ?
What have u / or could u have doen to make this happen ??
how old are ya ???
Ben
Old 16-03-2006, 08:01 PM
No offence was intended Ben, just like to check my sources are correct thats all otherwise we are lible to learn incorrect info, and as im sure you will agree... "Un informed, is better than Ill informed"
So what happens if you tear them and dont get enough protein to repair the fibres properly?
Agreed
Shoulders mainly
Dull ache
yes
No
Weight training
how old are ya ???
34
Ben
Replies in the quote
Old 17-03-2006, 08:02 AM
Ben26
Ben26's Avatar
well if u give your body a good blasting down the gym , yes u will ahe after the gym , but it should not be painfull, u have proberbly pulley a muscle or pulled a tendon.
protein will not take the pain away, u want to take some nosades ( ibroprofen ) take the swelling down. take 4 x 200 mg a day .
other than that restm it stu, do u know what movement u were doing to make this happen ???
Were on the shoulder is the pain exactly . front , back on the side , in the joint ???
or could u be over training, are u a gym begginer or have u been going long.
Do u know much about it really, ( not taklin the piss there mate )
just tryin to find out whats what really. they always teach u about clients knowledge and history
Ben
Old 17-03-2006, 08:41 AM
RSPTG
RSPTG's Avatar
If it was me I would rest for 4-6 days and then go back to light weights and patiently increase the weight on the shoulder gradually.
A rest will actually do you good and let the body recover. You seem to have a quality programme which you follow religiously so a break will give your body a good kick when you return.
As you have a break comming up Stu and you would like to continue untill then I would try and avoid any exercise that puts a massive load on that area or just stick to very light weight with reps you can handle say maintain 3x10. Any pain and leave well alone and take the time off, or you could be doing more harm than good.
Keep an eye on the diet while you are off and don't let all that hard work slip away, I would also keep protein at 0.8-1g per pound to maintain muscle but you could cut back on the carbs as you will not be training.
Old 17-03-2006, 08:45 AM
Ben26
Ben26's Avatar
all well and good mate , but pain is not a good thing when training , he really wants to get to the problem :
1. to not do it again
2. resolve it and learn from it
3. cure it properly
4. has he damaged anything so long term he will suffer ???
Ben
Bosch
04-08-2015 05:14 PM
The Sludge
Technical essay Archives
28
30-12-2008 09:00 PM
118
17-11-2004 10:04 PM
cossiemanden
20
06-11-2004 11:14 PM
The Gravedigger
01-11-2004 07:16 AM
Quick Reply: Pain, ALL THE TIME...
